I'm on 10.0.397 with the 2007 17in mac w/ 8600m video card. I'm still getting flickering in the viewport.
Good new tho, my menus are back!
Snow Leopard and Houdini good to go?
169809 162 5- ntmonkey
- 6 posts
- ykcosmo
- 288 posts
- bpinel
- 5 posts
- ykcosmo
- 288 posts
- MikeTaylor
- 154 posts
bpinel
The 9.5 production build and the daily build currently have the bug that prevent the user from accessing the menu.
It seems to be fix in the 10.x. Will it be backported ?
Regards,
I'm afraid that we will not be back porting Snow Leopard fixes to H9.5. If you need continued access to 9.5. Then you'll need to keep a copy of Leopard around.
We did a lot of work in H10 to improve the functioning of the Mac version. We highly recommend using H10 if at all possible.
- MikeTaylor
- 154 posts
ykcosmo
oh… it didn't flick this morning and flicked again this afternoon..-.-!
Has there anyone solved the flicker problem?
my machine is macbook pro..
So far, the flicker looks like a bug with the NVidia driver. We have notified our contact at Apple and have registered a bug with them. Hopefully they will have some news for us soon.
- ykcosmo
- 288 posts
- tmdag
- 168 posts
- ykcosmo
- 288 posts
- MikeTaylor
- 154 posts
- goldleaf
- 4164 posts
- ykcosmo
- 288 posts
- Lucas3d
- 3 posts
Hi all Mac OS X users,
I have a iMac 2.4 Ghz with a ATI RadeonHD2600 256 MB. I never test Houdini on Leopard. I install the version 10.0.401 fix the permission on the 2 folders. After that I can launch Houdini. Unfortunately, I don't have any icon and the interface is very very slow… 2-5 second lag on any process.
That issue is due by Snow Leopard or my iMac is too old ?
FX Developer at Dreamworks Animation
Maya / Houdini (hopefully I will witch this order soon :-)
- ykcosmo
- 288 posts
- MikeTaylor
- 154 posts
Lucas3d
Since you are on ATI, it's not likely a display driver problem. Make sure that you have X11 installed on your machine. It's an optional install on OS X. The program that we use to convert out SVG icons has a dependency on X11.
If you don't have it installed, you should be able to install it from your OS X install DVD.
- ykcosmo
- 288 posts
- Lucas3d
- 3 posts
MikeTaylor
Oups.. I true, I didn't install X11 (saving space on my small HD).
I will try that this week-end.
Thanks all for your answers, I feel less alone :-)
- xtimmyx
- 166 posts
- Lucas3d
- 3 posts
MikeTaylor
So after install X11, Houdini works well ! Icon is present and no openGL lag !
I don't create a big scene yet. Any way, I want only use Houdini at home on my iMac to practice it, if I'm not using it at work (some time I need to work on Maya).
Thanks for your help !
- ykcosmo
- 288 posts
