Bone length
4349 5 1- el_diablo
- 133 posts
- edward
- 7734 posts
- el_diablo
- 133 posts
- goldfarb
- 3455 posts
- el_diablo
- 133 posts
- grayOlorin
- 1799 posts
Well, this may be super late, but I ran into the same issue and I think I was able to find the solution.. Indeed, this has to do to how the capture regions are affected when changing the bone lenght. If you turn on the capture region display, you will notice that as you change your bone lenght, the cylinder inside the capture region “pill” changes, however the caps do not
To resolve this issue, simply adjust the Deform top Cap and Deform bottom cap channels under the Capture–> Deform region tab. You can eyeball it, but you could also drive it with an expression once you find the magic number
See the attachements so that you can see the parameters you need to adjust in addition to the bone length
Hope it helps!
Hope it helps!
-G
