New H11 materials render artifacts
   15181   19   1
the new H11 materials give render artifacts when used with default settings.
I know that I can increase shading quality, but with the old clay material, it works with default values.
Any idea what's causing this in the first place?
Regards,
Carsten
New_Materials_Render.zip (1.5 MB)
I have had this problem also with imported models.
rob
Gone fishing
looks like a self shadowing artifact, do you get the same thing with shadows turned off?
If not then try turning up the shadow bias on the light, maybe the default in H11 is lower.
Simon
Thanks for the hint, but this doesn't solve the problem: I get the same artifacts without shadows, and changing the shadow_bias value doesn't help, either! The only solution for the problem seems to be raytracing instead of micropolygon rendering.
Regards,
Carsten
I can get the exact same crazy patterns, on a test Budda model. After looking at the mantra ROP . I set the noise level on the sampling tab to 1 instead of 0.05. This got rid of the pattern.
The help states lower values produce less noisy images , this is clearly not the case. Maybe the default setting is incorrect or something under the hood that's either working incorrectly or broken.
rob
Gone fishing
Try rendering the model with “polygons as subdivision” - that should help. This option is on the object's Render > Geometry tabs…
rmagee
That's a creative choice, not a technical one - what if I don't want to render subd's?
circusmonkey
rob
Thanks! That did the trick for my model, too.
Carsten
stu
rmagee
Given the models shown in the images, subd's seemed like a reasonable option and a quick fix for now. As for non-subd models I am not sure why this is happening. I will mention it to r&d and maybe they can pinpoint the issue.
Robert
There is certainly something wrong with the noise value on the mantra rop
Rob
Gone fishing
circusmonkey
Rob
that doesn't seem to be the main cause or cause at all since all passes of example file use the same mantra node and the same objects and differ only in materials
all are rendered in H11 as i understood from carstenw's post
so there is probably something in new materials setup causing this
CG Supervisor
Framestore, NY
The images show the fault in H11 , coupled with rendered images from H10 which are fine. Since H10 and H11 also have totally different ROPs Ive just pointed out what seems to fix it .
I brought this very error up in the beta list ………………….
rob
Gone fishing
yes, but if you download the file and render out images for different passes you will see the problems as on carstenw's picures
you can also notice that only difference is in materials
all images are produced by the same ROP (H11) with the same settings
at least on my system i have the same results just by rendering out different passes
so i am only saying that even though noise level can fix this, it's default value is not causing it or at least it's something in the material(Surface Model) which is sensitive to this
CG Supervisor
Framestore, NY
just to clarify things: The renderings of my opening post were all done with the same Mantra 11.0 ROP. The “H10” in the picture caption refers to the “clay” material being imported from H10.
Carsten
These artifacts are a bug (a problem with Surface Model + micropolygon + triangle geometry). It should be fixed in the next build.
Andrew
I am still getting this problem. Did it actually get fixed?
using Houdini 11.0.733 on Linux 64bit Fedora
edit: Was exceptionally bad when using an area light and Mantra Shader Builder material. Also found with point lights, but not so bad - was able to remove by increasing noise value as described above. Not visible when using distant light.
So I guess it hasn't been completely fixed, but addressed.
Anyone else sharing my pain regarding this “super duper” shader?
File a bug :- with scene file
rob
Gone fishing
I had similar problem in XSI.
with caracter animation (envelop-xsi) (skining-maya)
after one day looking in problem, I discover that I have caracter on 10000-xt, 10000-zt,
and I moved caracter to 0,0,0, xyz, and errors was gone.
problem was in precision (float val).
so I think that your problem is same if it is not scale or position of your caracter than
is in material, look for values that can decrease precision of calculation.
goshone
YES!
Your still getting this issue with 11.1 ? . If so what did support say ?
Rob
Gone fishing
