Anyone buy Houdini: 101 Interface and workflow?
35111 54 2-
- Alanw
- 320 posts
Do you have the finished file for this lesson? It's called HERO1_v07.1.hip
He doesn't supply the same images of the woman's face that he uses in the lesson, but he does provide a subnet with animated text to illustrate this procedure. I followed and found it to work exactly the same.
The file naming he uses in the File COP is $HIP/textures/Ch07_textures.`padzero(4,$F+5)`.pic
Also, in order for Alt+E to open the expression editor you must have your cursor in a text field.
- isxaari
- 66 posts
- isxaari
- 66 posts
- Pagefan
- 519 posts
- probbins
- 1145 posts
Take a look at this simplified example and read the notes I've put in the null sop
“explanation”. This should help you understand how data is moved throughout houdini.
This file is also organized to suit H9 better.
“everything is coincident”
- isxaari
- 66 posts
~ when you download your file it won't save to the desktop it just opens. Its just odd.
I double click your “explanation” but nothing pops up?
Everyone is using this .PIC format. Do you have to use that .PIC format??? I am not sure how you integrated your pic into the .hip file but i can't do that because I don't know how so I will post the pic and my .hip file.
Odd. After looking at your file and your path I found mine.
My file was this
img/import_img/pic_out
so the whole line would read this if your going by my file
pic(“/img/import_img/pic_out”,$BBX,$BBY,D_CR)
I did change the CR to CB and CG respectfully when it called for it.
I can't seem to change my backgroud color but I can see the image alittle. I have never been this deep into it. Kind of cool kind of.
The only thing left is how he got his lines to be wavy on the cover art and the blue tent.
Anyways this is what i got so far. I placed the image on the desktop.
My file was this
- probbins
- 1145 posts
Just MMB on the explanation node, the comments are embedded in the node. If you want get to the editing interface for the comments the RMB on the node and from the resulting menu choose “Edit Comment”.
To change the background to black, move you mouse to the viewport and hit the “d” key. Then in the Display menu go to the Background folder and at the top-right choose the Dark colour scheme.
A small tip to help us, don't put spaces in your file names, use underscores instead. For us Linux users the blank spaces are a nuisance.
I would highly recommend that you go through all the video lessons in the Learning/Tutorials section of the website. Start with those on the second page, they are the ones posted earliest and the more basic, but all of the tutorials are for new users. Keep watch there since we post new videos quite regularly.
- probbins
- 1145 posts
As for create width for the lines, I'm not sure how Garman is doing it in the video, I haven't watched it.
The simplest way would be to pipe an AttributeCreate sop below the Point sop in the hip file I sent you.
In the parameters change the Name to “width” and in the first Value field put $CR. Make sure the render and display flag are set on the last node, the AttributeCreate and render.
This is a render effect so you won't see anything in the viewport. The lines will change width based on the red colour value.
- isxaari
- 66 posts
- probbins
- 1145 posts
- isxaari
- 66 posts
- isxaari
- 66 posts
- Alanw
- 320 posts
Garman uses a Point SOP to add the waves to the lines.
Specifically he uses this expression on the X & Y point position.
$TX + noise((($TX+0)*$my_noise_freq)+$T*$my_noise_speed,$TY,$TZ) * $my_noise_amp
For TY you just replace everywhere you see $TX with $TY. The other variables are custom variables that he used to keep the whole project procedural incase you wanted to go back and increase / decrease the number of lines or the amount of points in each line, etc. He does go over this on the DVD.
Also, just to note I got the expression above from the yellow color coded SOPS in the “cover_art1” subnet in the HERO1_v10.1.hip file included on the DVD.
Cheers
Cheers
- isxaari
- 66 posts
I have that dvd and I am watching it over and over again I do not understand. I need more detail. Like what to change to add or take away the wavey lines. There was a .Hip file posted on the first page that has a butterfly in it. Could you add that expression into that file so i can see how its done? I don't know how to apply that to my file and make it work thats why i ask. The dvd he say bah bah bah I DID THIS EARLIER ON but does not say anything on how to apply it to your image. Can you see were i am having problems? some say its a render only see now you say its an expression but even so what #'s would i change to make it wavyer or less wavyer. The .hip above is were i am at…still I know your mad and so am I this is 3 damn nodes that it. I STILL can't get it.
- Alanw
- 320 posts
- isxaari
- 66 posts
- isxaari
- 66 posts
- isxaari
- 66 posts
- isxaari
- 66 posts
- isxaari
- 66 posts
Come on H masters. It would take you 5 mins to do this effect yet after weeks I can't get it. Someone tell me how I can get those wavy lines like on the cover. It seems like alot of people have the DVD. It seems like he has 3 noise nodes going on and I don't know what #'s to key in plus my image just turns black so meh.
