Simple (or not simple) question.
What houdini build will not produce mantra multitread errors ?
I have strange errors with mantra rendering in versions from 182 to last build..
I start render, and go away, then i see red-colored mantra node and render is stopped in random time.
1. This error occur in random times. I`m do many tries and can`t understand the regularity rule..
2. This error occur on Win XP 64. Linux x86-32, Linux 86 OS. On Windows i see long long number of error code. On linux code number is “11”
3. Scenes for render contain the combinations of volumetrics, fluids or his caches, and lights..
[SOLVED] Multitreading mantra errors again
11750 17 2- live_fx
- 160 posts
- JColdrick
- 4140 posts
I've not noticed this problem recently, but then I'm not rendering a lot of what you describe, that might be related. By way of a diagnostic, do you notice any difference if you render to disk? I always found more of these problems when rendering to mplay back when they happened.
J.C.
J.C.
John Coldrick
- live_fx
- 160 posts
Thanks, JColdrick, but when i render to disk, this problem is happened too
i have some idea:
How i can start render, and take some dump file ? For example, some flag for mantra or for houdini ? Some debug string…
With this option i can send dump file to SESI developers team, i think this is a best solution..
Can mantra create a some dump file ? Or, if it created, where i can find it on Linux and Windows systems ?
Thanks for answers…
i have some idea:
Thanks for answers…
- live_fx
- 160 posts
Hm.. Right now i create some test scene, and start rendering. All ok..
i found some messages in system logs..
This very old logs:
Aug 5 02:27:02 livestation kernel: mantra-bin: segfault at b3e06008 ip 02b8dbf5 sp bfc33700 error 4 in libHoudiniUT.so
Aug 5 02:43:33 livestation kernel: mantra-bin: segfault at b7f07008 ip 01890bf5 sp b7e3aa30 error 4 in libHoudiniUT.so
Aug 5 17:29:16 livestation kernel: mantra-bin: segfault at b3cfa008 ip 08866bf5 sp bfe087a0 error 4 in libHoudiniUT.so
Aug 8 04:18:01 livestation kernel: mantra-bin: segfault at b3e02008 ip 02211bf5 sp b7e48e20 error 4 in libHoudiniUT.so
Aug 9 14:51:32 livestation kernel: mantra-bin: segfault at b3cbf008 ip 02bbebf5 sp bff69e20 error 4 in libHoudiniUT.so
Aug 9 15:14:34 livestation kernel: mantra-bin: segfault at b3e1e008 ip 0350ebf5 sp b7e3ce20 error 4 in libHoudiniUT.so
And this:
Aug 13 01:53:48 livestation kernel: mantra-bin: segfault at 31c1553140 ip 31c1553140 sp 44b9ea88 error 15
I think, libHoudiniUT.so - may be is a some files from GUI, may be mplay system files. But log from Aug 13 01:53:48 - i don`t have ideas.
Can i create dump files ?
This very old logs:
And this:
- wolf_cub_one
- 44 posts
I'm getting the same errors also. It just stops rendering at at random points with the error code 11. I reported to SideFx about this last week. I'm running Ubuntu 8.04 64-bit.
At first I thought it was due to motion blur but I did tests with and without motion blur and it was still happening. Are you using the Particle Fluid Surface node? My scenes are using it and I think it may be the culprit. Hopefully, I'll hear from SESI soon since this is really stopping me from using Houdini.
- andrewc
- 1002 posts
- wolf_cub_one
- 44 posts
I have already done so when I reported the errors to SESI. Just taking a slight break from Houdini since these are errors are causing me headaches. I'm just glad to hear now that I'm not the only person seeing these errors. Luckily, the Olympics are here to keep me from going insane due to these problems.
I just had to stop since all I've been doing recently is bug hunt and not getting anything done.
- live_fx
- 160 posts
andrewc, thanks, now i try to create lightweight simple scene, with this error receiving, and when i`m ready, i send bug report.
My scene now too big for email sending. I try to send via “Bug report” page, but receive error “file is too large” (i really like lock the some part of networks, and this produce large scene size, with locking for example, some volumetrics parts)
1. Now i`m disable all possible multitreading in all custom VOPs - no result. Errors again.
2. I don`t see mantra errors when only run mantra with -j1 flag, or set 1-processor rendering mode.
Today i want recreate some scene parts, and send little example + some system logs via “Bug report” sidefx.com page direct to developers.
- silvina
- 181 posts
- live_fx
- 160 posts
- live_fx
- 160 posts
- live_fx
- 160 posts
wolf_cub_one:
No, i don`t use particle fluid surface.. Only volumes, and lights with depth shadow maps..
One question: Does you have volumetrics in the scene or not ? Or depth-map shadows ? If you work with scene without volumetrics, and it crashed with same “Error 11”.. then i`m don`t understand anything now..
I`m not sure now - i`m correct, or not with my declaration of this bug.
- wolf_cub_one
- 44 posts
- live_fx
- 160 posts
- live_fx
- 160 posts
- wolf_cub_one
- 44 posts
- dr4ziw
- 5 posts
What build would that be?
I'm still receiving the segfault error (11) whenever I try to render anything with point clouds. To be honest, I've only tried it with Peter Quint's wetmap approach. When I hit render, it may render a few frames – the best I got were 25 in a row – but would also stop after the first frame.
I'm running:
- Ubuntu 10.04 64bit (besides the intended GCC4.4 build, I also tried the other ones, without luck)
- 4GB DDR2-800 RAM (after removing 2GB because they couldn't be run at full speed)
- NVIDIA GT9500 graphics card
- Houdini Apprentice 11.0.504 (that's not the latest build, right?)
Cheers!
- dr4ziw -
I'm running:
Cheers!
- dr4ziw -
- dr4ziw
- 5 posts
