Hi again,
I have got another hotkey question
Is it possible to create different sets of hotkeys and then assigning them to a key ?
Or … maybe not assign them, but just create different sets and then load them when you want :wink:
Thanks in advance
Julien
Another Hotkey question
4090 4 0- Undertaker
- 113 posts
- JColdrick
- 4140 posts
I don't think so, not directly, however if you look in your $HOME/houdini6 directory, there is a file there called “HotkeyOverrides” (assuming you've made some hotkey assigns already), and that could be managed outside of houdini. Whatever version of that file is somewhere in your $HOUDINI_PATH will be used for that session. That's the sort of thing that's fairly trivial to setup in, say, a houdini startup script. But no - I don't think you can load up a hotkey set dynamically in a given session.
J.C.
J.C.
John Coldrick
- Undertaker
- 113 posts
- will c
- 57 posts
- Undertaker
- 113 posts
