Hi
Im experimenting with bringing in audio via chops to control geometry deformations and etc. but houdini is crashing constantly when fidling with the sliders in the pass filter and the pitch chops?
Houdini version 9.5 (9.5.276)
MacBook Pro 2.5 GHz, 4 GB ram, GeForce 8600M GT
System Version: Mac OS X 10.5.5 (9F33)
- qral
audio chops crashing houdini on mac
5368 12 2- qral
- 52 posts
- circusmonkey
- 2624 posts
- qral
- 52 posts
- probbins
- 1145 posts
I'm not on a mac. Tested it on Ubuntu 8.04, with houdini 9.5.224, nvidia graphics, and not encountering your problem. Moving the sliders at a single static frame or while running the animation causes no problems.
So both the hipnc and audio files seem fine.
What audio drivers does you mac use? Is it being served by Nvidia?
“everything is coincident”
- qral
- 52 posts
- probbins
- 1145 posts
- rafal
- 1449 posts
- andrewlowell
- 537 posts
Looks fine on my machine as well. When exactly does it crash? Simply when adjusting the pass filter while not playing? Have you tried the filter chunk size at the default setting and still crashes?
I can't test this on a mac either but usually the main reason I've seen audio crash on the machines I've used (win or linux) is memory. But 4 gigs should be quite enough.
One thing you might try is downsampleing the resulting audio to drive the animation. But, I wouldn't suggest trying to manipulate the sliders while playing if it's doing this.
- qral
- 52 posts
Thanks for all of your replies…
@ Probbins: I haven't found a way to allocate some more ram for the audio driver…
@ rafal: I will test if thats the case…
@ andrewlowell: It seems like the pass filter is doing ok when leaving the chunk settings on default. The pitch node seems like the most unstable especially when dragging the “minimum level” slider to the lowest value.
I think some of my first crashes was triggered by dragging the sliders while playing…
- qral
- qral
- circusmonkey
- 2624 posts
- edward
- 7733 posts
- qral
- 52 posts
- edward
- 7733 posts
