I've been playing around with the cloth system applied to a sphere in order to make a balloon colliding with the ground
(i'd like to make it like The Ball in the tvshow The Prisoner actually)
the thing is that after looking up in the “material” tab of the sphere in the DOPnetwork I still don't really get how to achieve the behavior of a realistic rubber (for instance the geometry won't really get back to its initial shape if I want it to bounce)
I don't really get the difference between the shearstiffness, the stretchstiffness , and if I should use the plastic hardenning or plastic flowrate and so on. And the range of values I should use
anyway I would really appreciate any advice about this or maybe someone here allready have achieved this effect …
all answers are welcome here
thank you guys
cheers
balloon-like behavior with cloths
7054 8 1- jlautret
- 34 posts
- jlautret
- 34 posts
- tamte
- 8587 posts
- varomix
- 460 posts
- tamte
- 8587 posts
there is one disadvantage of squishy object over cloth for softbody sim
sqishy objects are simulated as particles and i think you can't get mutual collisions between two sq objects
so if you need only ball/ground collision go for squishy object
if you need ball/ball collision, it probably won't work in one simulation, but there may be some workaround i am not aware of
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- jlautret
- 34 posts
- jlautret
- 34 posts
- tamte
- 8587 posts
- jlautret
- 34 posts
hmmm, I'm not sure to get it
i appened a delete sop after dopimport as you told me ..then I put the popnetwork in the “pattern” of my “delete by pattern” option (am I right so far? )
I played around with the others attribute like changing the “geomerty type” and thoses kind of things but it doesn't seem to change anything
am I forgetting something important?!
thank you for your reply by the way
regards
regards
