how to create group by color
   32087   5   2
Hi I would like to ask how to create group in SOP cording to Color Attribute, i am newbie , thanks for kindly help.
what node and how i search in the help context with keyword “group color” but didnt find the information i want.
Thank you very much.
Group by expression,
something like $CG>0.8
“everything is coincident”
You can use the partition SOP to group by attributes.
I think it has a preset for grouping by color.
http://www.sidefx.com/docs/houdini10.0/nodes/sop/partition [sidefx.com]
If you like to put down a bunch of group SOPs manually which is quite error prone. Works for one or two groups based on an attribute. Not for what you want.
A better method is to use the Partition SOP. It even has an option “Group by Color” in the Rule parameter's right hand arrow menu button. Choose that option and you will have a group for each unique color.
partition and assemble sop.
like if you wanted to crack something.
thanks , i am using partition SOP for what i need, thanks for everyone
