whenever I write an expression of an object, it takes me quite a bit of time to type the path of the object correctly.
e.g. /obj/model/grid/TX……………….
I would easily make some typing mistakes. Does anyone know a convinient way that I can get the path of a object or channels very quickly and accuately?
a simple question about about expression
3201 3 0- brucelay
- 313 posts
- goldfarb
- 3455 posts
- JColdrick
- 4140 posts
RMB over the channel you'd like to reference(either over the value field or the name label), and select “Copy”, then RMB over the place you'd like the reference to go. There's lots of options there - among them are Paste Copied Reference, which will put absolute paths in your expression, or Paste Relative Reference, which will use “../../” etc.
Drag and drop also works when both panes are up, otherwise this is more accurate. Of course, being a fast, accurate typist is also an option.
J.C.
J.C.
John Coldrick
- goldfarb
- 3455 posts
