I am trying to write animated geo to disk using bgeo format.
I did put $F in the path to save the animated geo.
But, I can save only one frame. Can any one help me Please ?
OR,
I put Objmerge sop to bring in another obj before i merge it to another objs in sop level. I still can not write all the frames to disk. Missing some or many frames.
Steve
Help Me in Saving to BGEO Format
5461 14 3- aplink
- 365 posts
- circusmonkey
- 2624 posts
- aplink
- 365 posts
- circusmonkey
- 2624 posts
- JColdrick
- 4140 posts
- aplink
- 365 posts
- Antoine Durr
- 321 posts
aplinkIt sounds like something is seriously messed up with your installation – you're having all kinds of problems none of us ever see. Are you sure the version of Houdini you're using is the correct one for your OS version? Are you using an official Apprentice or HD version (or actual Escape or Master license)?
No, I am not trolling.
I wonder why i am having hard time in writing to dick.
I checked ROP, It's OK. I set it frame 0-24
- jason_iversen
- 12482 posts
Sounds like you're out of disk space
- aplink
- 365 posts
Thanks to getting back to me.
I am using pretty new Mac Pro (Refurbished) and i just updated the latest build of houdini.
I am so frustrated with my houdini because i used to have Default Mantra problem. Seems like it is working normal after i updated a few days ago.
But, I've had a tremendous problem in writing files to disk.
sometimes it works, sometimes it doesnt work at all, sometimes it it writes only partial frames(not all the frames).
I wonder why ? I wasted whole lot of time just for writing files to disk.
Can you help me please ?
Steve
Steve
- aplink
- 365 posts
- JColdrick
- 4140 posts
- aplink
- 365 posts
- aplink
- 365 posts
- rdms
- 201 posts
aplink
Sometimes i can write the animated file to disk by running the animation.
Otherwise, i only can write it the only frame number where my obj sit on.
I wonder why ? Can any one help me ?
Steve
When you say ‘sometimes’ does that mean it sometimes works or the only way is to run the animation?
Can you send a simplified hipfile that recreates this problem?
Rob
Digital Supervisor | Stargate Studios Toronto
Rob
- aplink
- 365 posts
