Some one can be nice and place few simple examples to cover the Transform VEX node basic abbilities and uses.
J.
Simple Examples for Transform VEX node
5469 5 0- James_Burg
- 153 posts
- Dennis Weil
- 150 posts
James_Burg
J.
Hi James,
are you interested in the Transform VOP or the Transform Matrix VOP? They are doing completely different things.
The Transform Matrix VOP is able to actually transform vectors in space (edit the vector so it has a new orientation/position/length) while the Transform VOP just changes the Transform Space of a vector (the vector itself is not changing, we are just looking at it from a different point of view).
It would help a lot if you would specify what you are trying to achieve, as these nodes can be used in countless different ways.
-dennis
- James_Burg
- 153 posts
Thank you for the reaply Dennis,
I just reading posts in the in forum from time to time,
I`m not using VOP frequently and it will be nice to learn new things…
I was intrested in “transform node”,
for example i saw some one using ramp oportaion using object space instead of world space, (if i`m not wrong)
I just need more practical examples to get more solid understading.
but, in general,
sidefx assume that everyone who reads the help card have expiriance in
more low level oporations of a 3D and played with that in few other cases.
It will be nice if few simple examples will be published for every oporation in vop.
J.
but, in general,
J.
- James_Burg
- 153 posts
- aeaeaeae
- 126 posts
- tamte
- 8591 posts
