Hey guys,
I was following the quick start tutorial and I've followed the column one step by step and I'm stuck at a certain point. When I add the “Make Breakable” modifier to the circle of columns and simulate it, all the columns start smashing and at the base instead of the impact point of the ball. It seems to me that they may be “falling” on to the ground plane, but I'm not exactly sure. I'm using Houdini 12 btw and I've attached a screenshot. Any help would be appreciated.
Smashing columns
4501 5 1- MPiland
- 16 posts
- goldfarb
- 3455 posts
- MPiland
- 16 posts
- circusmonkey
- 2624 posts
- MPiland
- 16 posts
Thanks. That seems to work, somewhat, but it's still not getting the same effect as the tutorial video. I see what you did, though and it makes sense, but it still doesn't seem to fracture the column when the ball hits, only when the columns hit each other. But, I figured out how to make it work. I had to put the sphere name in the Impact group box and that worked perfectly. I guess that's the difference between Houdini 11 and 12? lol But why is it in the tutorial he doesn't change any of the parameters and it works just fine? If I add the sphere into the impact group, it's also smashing the columns before the sphere actually hits them.
EDIT: Figured out what the major issue was. I didn't even have to change the Impact Group. In the rigidbodysolver1 node, the solver engine was set to Bullet…I changed it to RBD and it worked exactly as planned. So, Bullet was the problem.
- rolma
- 2 posts
