Hi All,
Is there an elegant way to calculate and display the intersection between 2 objects. From which I could generate some points. I have done it before using the area and curvature attributes which gave me a colour attribute via vop sops but I was thinking maybe there's a more elegant way of doing it.
ie in the simple scene I have a sphere and grid and all I want is points to be generated or an attribute that can be used, where the sphere and the grid intersect each other.
Rob
Intersection between geometry objects
7992 3 1- circusmonkey
- 2624 posts
- VisualCortexLab
- 509 posts
Jeff posted a pretty nice tutorial a while ago that might help you:
http://www.sidefx.com/index.php?option=com_content&task=view&id=1815&Itemid=216 [sidefx.com]
hope that helps.
hope that helps.
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
- goldfarb
- 3455 posts
first of a two part tutorial:
- circusmonkey
- 2624 posts
