findClosestPoint not implemented
3108 4 0-
- KMcNamara
- 228 posts
- sanostol
- 590 posts
- KMcNamara
- 228 posts
Thanks for the reply! Unfortunately I am trying to implement non-uniform Poisson sampling and I don't know the locations until I'm actually generating them from within Python, so I can't store closest points beforehand. Further, each new point that I generate depends on the previous point's closest point, so I need to get able to get the closest point during run time of the python code.
The reason I need this is because I have to create noise on a grid beforehand and then sample that grid for its noise values. (I have to do this because most of the noise functions are also ‘not yet implemented’ in Python
- KMcNamara
- 228 posts
- symek
- 1390 posts
KMcNamara
Is there a way to call a VEX function from within Python?
Indeed there is: http://www.sidefx.com/docs/houdini12.5/hom/hou/runVex [sidefx.com]
I'm not saying this is good idea though. I haven't touched that field for a long time but I would start with generating points up front and use VEX for placing them around (unless there is something in it, I'm not aware of).
