hi all,
i have several questions about flip in H13.
1. is it possible to cache flip sim first and read them from file node , use cache file to sim white water splash and foam?
2. if im working on a heavy flip simulation,
any possible to reduce loading time when im simulating splash ? (fluid has already cached.)
3. any info about H13 simple flip workflow to study?
hope someone could give me some advice or answer ?
flip question
3254 8 2- nickel0531
- 9 posts
- Solitude
- 373 posts
1) Yes. Absolutely, that's how you should be doing it. When you create a flip simulation from the shelf tools it will set up a dop i/o node. You can cache the sim to a bgeo sequence there.
2) Not really. The files are big, and take time to load. The one thing I've done is split out volumes and particles to separate files so I don't have to load everything at once.
3) There isn't much available (though I'm considering doing a flip video tutorial series). The workflow hasn't change too much since 12, so I'd suggest watching the waterfall videos from sidefx.
Ian Farnsworth
- anon_user_37409885
- 4189 posts
- nickel0531
- 9 posts
- nickel0531
- 9 posts
hi! i have another question about the flip collision .
https://vimeo.com/72158370 [vimeo.com]
this is basic tutorial about flip workflow.
and i noticed that he used vbdfrompolygon to set as collision object.
does vdb calculate faster than geometry?
i tested between origin and vdb obj, and not as much faster as i expected.
am i misunderstanding about vdb ? :?
- SkippyLink
- 19 posts
Hi nickel,
Don't know how helpful it will be but I uploaded a video last night after doing a bit of flippy rnd.
https://vimeo.com/89257834 [vimeo.com]
Might be helpful to look at the sudden leap of file sizes and point numbers between 0.050 and 0.025 particle separation.
I rendered out the flip sim, then used those .bgeos to produce the whitewater and VDB mesh. (Which I also rendered out as separate .bgeos).
I found that once I dropped below 0.050 particle separation the load times for the .bgeos was a noticeable bottleneck so if I was working on those further I'd move those across to an SSD.
Not looked at what loads faster, VDB or Poly, I'm presuming VDB.
Hope this a little helpful
- eetu
- 606 posts
SkippyLink
When you cut the particle separation in half, the resulting resolution (in particle count and volume divisions) increases 8-fold. Your numbers seem to follow that pretty much as expected, if you compare the 0.050 -> 0.025 as well as the 0.100 -> 0.050 numbers.
- nickel0531
- 9 posts
- Sadjad Rabiee
- 1391 posts
