Not sure whether this is a bug, or a setting/pref that i'm missing somewhere.
I can somehow get houdini into a particular ‘state’ which draws multi-input sops as single input. If you jiggle the node, the approporiate number of inputs reappear.
Have a look at a selection of multi input nodes drawn incorrectly:
incorrect number of inputs on sops.
4082 15 2- keyframe
- 1532 posts
- graham
- 1908 posts
- keyframe
- 1532 posts
- anon_user_37409885
- 4189 posts
- graham
- 1908 posts
- keyframe
- 1532 posts
- 4189 posts
- stu
- 246 posts
- pbowmar
- 7025 posts
Yes this is an ongoing issue, happens to me 100% of the time using Copy SOP for example.
Drag and Drop turns itself off.
Tooltips turn black.
In fairness, Halfdan has spent quite a bit of time trying to track it down with no luck.
Unfortunately, the longer these things persist the more it feels like Houdini is accumulating a lot of papercut annoyances
Peter B
Peter B
- 4189 posts
pbowmar
It's reported and is being attended to currently:
Drag and Drop turns itself off.Whats the drag and drop issue and we'll try to hunt it down?
Thought the Tooltips was fixed/screensave issue. No issue on OsX to test with.
Looking at other 3d softwares, Houdini stands up very well. Compare it to something like MS Word and it's brilliant! - apparently the code is so large that no one person can read it all and there are bugs from the original version still in there. No one knows what will happen if they touch it so they don't
- pbowmar
- 7025 posts
SESI is very aware of all these issues, I've done screen-share sessions or screen-caps to show all of them. They've been in there for a couple of years now.
You are correct though, Houdini 12.5 was extremely stable and hopefully there will be a 13.1 or 13.5 that is a stability release too!
Peter B
Peter B
- 4189 posts
- pbowmar
- 7025 posts
- 4189 posts
- pbowmar
- 7025 posts
- 4189 posts
