what the title says. I recenly updated my drivers to be able to properly test new Houdini versions and since I did it I´m having display problems. Objects appear on wireframe view, but I can´t see them on solid views…
It tends to happen more when I open cached geometry than when I´m creating it myself…
anybody else got this? I understand it´s not one of the recommended cards, but it workd perfectly before…
Yes I am having issues with the new Nvidia drivers as well. Have GTX680 and now flat shaded views dont display polygonal objects only nurbes in GL3.3 very irritating.
I'm in the process of learning Houdini, and came here to report this issue. I'm not terribly surprised that the bug has already been mentioned, but I am amazed that Side Effects has already fixed it. :shock: Some other companies could learn a lot from your responsiveness to customer issues.
They said they had to roll back the changes to teh driver due to older Nvidia drivers not being able to function properly .560 build works for newest drivers tho if you can get it still.
kreahk They said they had to roll back the changes to teh driver due to older Nvidia drivers not being able to function properly .560 build works for newest drivers tho if you can get it still.
Okay, thanks for the explanation. For now, I've fixed the problem by installing the NVIDIA 340.52 driver.
