I am trying to use “asin()” and “acos()” to calculate the rotational angle of an arbitrary edge in the XZ plane. However, these functions seems to make Houdini crazy-unstable. The functions calculate the first or second time just fine. There after Houdini crashes and I must start over.
“User-Error” on the trig functions?
I'm thinking of abandoning the angle calculation and just using the “buildLookatRotation” function based on a faux object sitting on the perpendicular bisector.
Any other suggestions?
Trigonometry functions crashing Houdini
2372 2 1- rudeypunk
- 113 posts
- goldfarb
- 3455 posts
- rudeypunk
- 113 posts
Thanks for the reply Michael -
Shucks - It seems by creating a “simple” example file I fixed my problem. (Or at least proven I did not have a problem. )
I must be creating the instability someplace else.
Regardless, I am posting my example hip file to demonstrate the numerical technique to calculate the rotation. The idea is to always make sure "point" is always pointing down the positive X-axis.
Thanks for your help
