Extract in context?
1968 8 2- Werner Ziemerink
- 1265 posts
- animatrix_
- 4517 posts
You mean using the Scene View tab menu? Have you tried the context menu on the Scene View?
youtube.com/@pragmaticvfx | patreon.com/animatrix | animatrix2k7.gumroad.com
- Anonymous
- 678 posts
Look at this menu:
Ream more about it here:
http://www.sidefx.com/docs/houdini14.0/model/create [sidefx.com]
edit:
Puscat was first
edit:
Puscat was first
Edited by - Sept. 7, 2015 14:30:47
- Werner Ziemerink
- 1265 posts
- Werner Ziemerink
- 1265 posts
- animatrix_
- 4517 posts
Did you also try the new Split SOP?
- Werner Ziemerink
- 1265 posts
The split SOP would work fine if the original mesh stayed in tact…or at least had an option to preserve original mesh.
Basically I want to duplicate a primitive selection and be able to translate the new extracted peace somewhere else with one click. I the Extract SOP worked when switching to Create in Context it would be great.
I will submit a RFE, but wanted to makes sure I'm not doing something stupid.
- tamte
- 8567 posts
Werner Ziemerink
well it stays intact, however not as part of the same flow as split geo
so what you are describing sounds like Duplicate Shelf Tool in Context on selected primitives, which should work just fine
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Werner Ziemerink
- 1265 posts
