I thought it was something else but when Houdini main window is in the background and I have Chrome on top of it completely covering the screen, the Houdini window pops up.
This kind of thing sometimes happen but very rarely, but I see this happening dozens of times an hour.
Anyone else has seen this with H15?
Does Houdini 15 steal focus on Windows?
5357 14 2- animatrix_
- 4515 posts
youtube.com/@pragmaticvfx | patreon.com/animatrix | animatrix2k7.gumroad.com
- Enivob
- 2537 posts
- RepubliCommando
- 6 posts
- Andr1
- 118 posts
- animatrix_
- 4515 posts
I am still seeing this issue. It would be nice to have a fix. It also happens to me while using Chrome.
I minimize all Houdini windows to avoid this but it's a hassle.
- Enivob
- 2537 posts
- animatrix_
- 4515 posts
Ignore the guy who suggested to upgrade to Win10, he is a troll.
I have a strong feeling that this might be happening when the mouse goes outside the bounds of Chrome and onto Houdini's visible windows. I am using a tablet so it's possible that my cursor goes outside chrome for a split second and then Houdini forces itself to be in focus. I am not sure but this is a possibility.
- rvinluan
- 1255 posts
- animatrix_
- 4515 posts
Thanks Rob. The best I can tell is which happens very often without fail is leaving Houdini open on a dual screen monitor, one for the main app window and the other window is a floating pane for the viewport covering the second monitor. If you open a chrome window on top of Houdini and use it with a wacom tablet, it should happen.
I will try to narrow it down further this weekend.
EDIT: I just tried it and it happens whether you use a mouse or a tablet. And the step to reproduce is to move your mouse to this second non-main window which is a floating pane that contains the viewport and then back onto the area where chrome is, network editor should appear on top within seconds.
Edited by animatrix_ - June 11, 2016 18:54:25
- anon_user_37409885
- 4189 posts
- rvinluan
- 1255 posts
pusat
I gave this a try and still couldn't reproduce.
However I tested on Mac OSX since that's what's readily available to me. Tested with the “Keep Floating Windows on Top” preference turned on and also turned off.
I'll track down a Windows setup here and give it another go…
- Andr1
- 118 posts
- jerry7
- 620 posts
- animatrix_
- 4515 posts
It looks like SESI fixed this bug:
Houdini 16.0.654
Fixed a Windows-only bug where the main Houdini window would sometimes pop up in front of other application windows even when Houdini is not the active application.
Houdini 16.0.654
- Andr1
- 118 posts
