please help, I can not pass the 3:44 minute, this in linux, but the route is with the “/” and I Temgo windows, my route is this F: \ houdini \ bhv \ Archive, but when you I enter, tells me not to find the route, some help please do it in windows, thank you very much!
This is the link to the tutorial.
https://vimeo.com/128729379 [vimeo.com]
Install BVH Into Mocap Crowd Agent help!
2984 5 1- olympusRaul
- 24 posts
- Enivob
- 2537 posts
You do have to specify the full path and filename, not just the path. Also the full path should not have any spaces in the path. Make sure your user name for the system does not have any strange ASCII characters in it.
I have attached the example 08_02.bclip and .cmd files referenced in the video. Just use the .bclip to continue the video even if you can not get the convert to work.
Edited by Enivob - July 3, 2016 09:45:23
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- olympusRaul
- 24 posts
Enivob
hello failure again because in this tutorial, use linux, I have windows, and does not allow! help!
Artist CGI
- goldfarb
- 3455 posts
- olympusRaul
- 24 posts
- neil_math_comp
- 1743 posts
One awkward thing is that Houdini doesn't support backslashes as directory separators in paths. I wish it did support backslashes, but you have to use forward slashes, even on Windows, e.g.
F:/houdini/bhv/Archive/08_02.cmd
