Hey guys. I'm completely new to Houdini. Just got into it recently, so i don't know much.
I just created a pop network, some particles emitted from a turbulent noise (used to delete non-selected polys) on a geometry (Torus for now) and then instanced (copy) spheres onto each particle. I'm using the copy stamping to randomize the scale, and noticed that when doing so the playback / caching speed has dramatically dropped. What was priory almost real time takes now about 20 times slower. Any particular reason for that please? Am i using a wrong approach?
Thanks in advance.
A.
Copy stamping / Random scale slowing down playback / cache?
6320 9 2- Adriano
- 408 posts
- sepu
- 419 posts
- Adriano
- 408 posts
I did. It didn't change anything.
If i turn off “Stamp Inputs”, the playback with all the spheres (of identical scale) is fast again. But with “cache stamping + Pack geo before copying” or not, as soon as i turn on the “stamp inputs”, it starts choking again.
Actually it's inaccurate. It's as soon as i use “rand($PT)*2” expression in the variable 1 (scale) value of the “ Stamp inputs” that things get terribly slow. Because using Stamp inputs variable (scale in my case)with an integer value does not slow down anything.
Am i using an old vex expression? is “rand($PT)*2” obsolete or something?
A.
A.
Edited by Adriano - Jan. 22, 2017 19:13:43
- sepu
- 419 posts
- sepu
- 419 posts
- Adriano
- 408 posts
- sepu
- 419 posts
- Adriano
- 408 posts
- circusmonkey
- 2624 posts
Only pscale / Cd will work like that as its internally handled by default. What you can do is set your attributes on the template geometry and then stamp that attribute in the copy sop. Also make sure to pack your geometry either before input into the copy sop or on the copy sop.
Rob
Rob
Edited by circusmonkey - Jan. 22, 2017 20:12:18
Gone fishing
- Adriano
- 408 posts
