I'm trying to create procedural rock generator and during tests with creating normal map from hipoly version to lowpoly I hit a wall.
Gernerator creates UVs for lowpoly version:
Added baketexture node in Out Networks, and after setting UV Object1 to lowres version of generator, and HighRes Object1 to hires I got (black/white image without any details for all output formats, tangent-pace notmal, displacement, occlusion, cavity, etc):
I tried also use scaled up version of lowpoly geometry to use as UV Cage Obejct1 with exactly same result.
What am I doing wrong? I could use xnormal after exporting both geometries to obj files but as Houdini allows that approach it could be nice to have this all-in-one place, generator will be used to create different variants of rocks as game assets.
Baketexture from hipoly to lowpoly renders only white/black image without details
2860 3 1- Tomasz Kolaj
- 7 posts
- Tomasz Kolaj
- 7 posts
- mark
- 2591 posts
http://www.sidefx.com/docs/houdini/props/mantra [www.sidefx.com]
It's the first property if you search for “Baking Properties”. We'll see about updating the Mantra User Guide.
- jsmack
- 7771 posts
