I have a VOP HDA with data type signatures. If another signature becomes active, the operation works with it. But the UI inputs disappear
I'm wondering if there's something extra I can do to avoid this or it's the way it is. UI is only supported for one signature?
Cheers
HDA - Signatures - UI
2267 5 0- probiner
- 339 posts
- jsmack
- 7800 posts
- probiner
- 339 posts
Thanks to Tomas Slancik for the help in the discord server, here's a quick vid about it the answer to this:
https://streamable.com/049si [streamable.com]
cheers jsmack
cheers jsmack
Edited by probiner - June 30, 2017 22:39:45
- tamte
- 8583 posts
you don't need to create array parameters
delete them, just keep the input defined in inputs/outputs tab (visible toggle seems to not be hiding the input though, maybe a bug)
deleting parms will make that initial value disappear as well, so no pop necessary
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- probiner
- 339 posts
- tamte
- 8583 posts
