So, I'm trying to do something trivial in POPs, but it's baffling me in DOPs. Basically I have a curve in space, and I want a force to run along the curve. In POPs, I'd just copy the metaballs to the curve's points (with the normals pointing down the curve) and use a Force SOP.
How do I achieve this in DOPs? The Magnet Force DOP makes no sense to me (and has no example or useful help, sadly) and the Point Force works OK but how do I get each point on the curve to have a force, picking up the normal's direction from the curve?
Peter B
DOPs: Point force or Metaball force, how?
6187 4 1- pbowmar
- 7028 posts
- wolfwood
- 4262 posts
pbowmar
You could use the Copy Data DOP
For the number of copies you would use npoints(“sopCurve”)
Then in the Point Force DOP you would use the point expression to fetch the position of each point and normal.
Force:
point(“../../pointForces”,stamp(“../copydata1”,“PtNum”,0),“N”,0)
Position:
point(“../../pointForces”,stamp(“../copydata1”,“PtNum”,0),“P”,0)
- mtucker
- 4453 posts
If you want each point on the curve to only influence objects within a certain radius of that point, I'd suggest a Field Force DOP (which does have a couple of example files on the help card). The approach above will apply forces from all points to all objects. Using the Magnet Force DOP will always create a force along the gradient of the metaball, and so won't let you direct the force along the curve.
An RFE has been added to provide a DOP force that is equivalent to the Attractor POP or the Force input on aParticle SOP.
Mark
Mark
- pbowmar
- 7028 posts
- pbowmar
- 7028 posts
