Mantra render trouble
2255 7 1- marque_pierre
- 25 posts
- anon_user_37409885
- 4189 posts
- dlee
- 424 posts
- marque_pierre
- 25 posts
- dlee
- 424 posts
- marque_pierre
- 25 posts
- robsdesign
- 236 posts
Hi, this looks like preview render artefacts to me. Try unchecking Preview on your Render View tab. (Not sure if you've done this via other methods (ie render to disk) and it still shows up)
If you're looking to reduce noise, you may be interested in my recent post. It focuses on indirect_reflect noise which might be useful for your scene. https://www.sidefx.com/forum/topic/51712/ [www.sidefx.com]
Looking at your settings, to reduce noise, I'd recommend looking at the following…
Reduce pixel samples - Combined with the following, you may not need any more than 3 pixel samples. 4 might be a sweet-spot but this may cause an issue which is described in my post. (so 5 might actually be needed)
Reduce Noise level - I usually add a zero out of habit and look at min/max samples if I need to.
Increase reflection quality - You can set this quite high (ie 10) and get better results than increasing pixel samples.
Increase diffuse quality - You probably won't need to set this very high. (ie 2-4)
Decrease your diffuse limit to 1 - Increasing this can give more realistic results but does increase noise and render times, increase gradually if you need to.
Increase Environment light quality - You can reduce direct_reflect noise with less impact on render time than increased pixel samples.
Rob
Rob
Edited by robsdesign - Sept. 19, 2017 06:08:51
- marque_pierre
- 25 posts
