https://www.sidefx.com/tutorials/goz-plugin-for-zbrush/ [www.sidefx.com]
I did install plugin as instruceted in video but i do not get gz plugin shelf and yes i did restart Houdini
Hitting “+” sign and selecting “shelves” does not have GoZ listed
Goz Plugin not working in new version houdini?
6963 7 1-
- ISUther
- 116 posts
- goldfarb
- 3465 posts
the tool has been updated:
https://www.dropbox.com/s/cibtavd9hm0686u/goz_installer16_5.hda?dl=0 [www.dropbox.com]
- friedasparagus
- 402 posts
- Cyzor
- 181 posts
- Njordy
- 27 posts
Cyzor
Note that the otl assumes you're running Windows. I'd have to take a closer look to remap the paths for potential compatibility with other platforms.
Yeah, I'd love to use this HDA, but sadly I'm on macOS. I know what I need to change in zbrush_dir and brush_proj_dir, but have no idea what to do about GoZMakeObjectPAth.exe and so on…
Have anyone figured it out?
- cgbeige
- 99 posts
back when the Maya version was out of date, I wrote a script to do a similar thing just by dragging and dropping exported OBJ files onto the ZBrush app in macOS since that imports the mesh. I don't know what sort of interop you need but that type of thing is easy to write for Houdini since you just make a drag and drop of your geo the post-render script action. Try the attached scene – it works for me. You might need to change your path to ZBrush in the geometry ROP's script since I'm using floating license version that has a different path
Edited by cgbeige - Feb. 21, 2018 15:14:10
- Njordy
- 27 posts
The HIP you attach consists of three heightfield node and nothing about saving geo
Anyhow, I tried to fix the code from original HDA.
The thing is, Zbrush starts after pressing the button, but immediately crashes. I dunno why. *goz files stays in the project folder, I tried to open it directly from Zbrush — same thing, crush. What can be the problem, somehow files are corrupted?
Maya GoZ works perfectly.
import os import subprocess zbrush_dir = "/Users/Shared/Pixologic/GoZBrush" zbrush_proj_dir = "/Users/Shared/Pixologic/GoZBProjects/Default" def get_mesh_paths(meshes_to_send): paths_to_meshes = [] for mesh in meshes_to_send: ## object_path_file = os.path.join(zbrush_dir, "GoZ_ObjectPath.txt") object_path_file = "/Users/Shared/Pixologic/GoZBrush/GoZ_ObjectPath.txt" f = open(object_path_file, 'w') f.write(mesh + "\n") f.close() object_path_exe = "/Users/Shared/Pixologic/GoZBrush/GoZMakeObjectPath.app/Contents/MacOS/GoZMakeObjectPath" subprocess.call(object_path_exe) ## object_path_file = os.path.join(zbrush_dir, "GoZ_ObjectPath.txt") object_path_file = "/Users/Shared/Pixologic/GoZBrush/GoZ_ObjectPath.txt" f = open(object_path_file, 'r') for line in f.readlines(): print line paths_to_meshes.append(line) f.close() return paths_to_meshes def write_object_path(path_to_meshes): # object_path_file = os.path.join(zbrush_dir, "GoZ_ObjectList.txt") object_path_file = "/Users/Shared/Pixologic/GoZBrush/GoZ_ObjectList.txt" f = open(object_path_file, 'w') for path in path_to_meshes: f.write(path.replace("\\", "/") + "\n") f.close() def export_subtool(instance): meshes_to_send = [instance.parm("tool_name").eval()] paths_to_meshes = os.path.join(zbrush_proj_dir, meshes_to_send[0]) if instance.inputs(): instance.node("OUT_MESH").parm("sopoutput").set(paths_to_meshes+ ".GoZ") instance.node("OUT_MESH").parm("execute").pressButton() def export(kwargs): meshes_to_send = [hou.pwd().parm("tool_name").eval()] export_path = hou.pwd().node("OUT_MESH").parm("sopoutput").eval() paths_to_meshes = [os.path.join(zbrush_proj_dir, meshes_to_send[0]).replace("\\", "/")] write_object_path(paths_to_meshes) if hou.pwd().inputs(): hou.pwd().node("OUT_MESH").parm("sopoutput").set(paths_to_meshes[0] + ".GoZ") hou.pwd().node("OUT_MESH").parm("execute").pressButton() # object_path_exe = os.path.join(zbrush_dir, "GoZBrushFromApp.exe") object_path_exe = "/Users/Shared/Pixologic/GoZBrush/GoZBrushFromApp.app/Contents/MacOS/GoZBrushFromApp" subprocess.call(object_path_exe)
- Njordy
- 27 posts
I also have problems with GameDev Toolset because I'm a Mac user.
Sadly, there are HDAs what points to an app on file system… they never check (if it's possible in Python, and somehow I think it is) what OS user is running. GameDev Instant Mesh node will never work on Mac (*nix also) machine since it always points to “$HOUDINI_USER_PREF_DIR/Instant Meshes.exe”. And for some reason “/Applications/Instant Meshes.app” nor “/Applications/Instant`/n`Meshes.app” (I actually have no idea how to deal with spaces in filenames, Houdini Help just says to not use is
) doesn't work.
The Python node inside the asset shows this:
I dunno if it's a problem with old Python system uses, permission issues, file path string, or Instant Mesh itself doesn't support this interaction on Mac. Maybe someone can help.
) doesn't work. The Python node inside the asset shows this:
Python error: Traceback (most recent call last): File "", line 38, in File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 522, in call return Popen(*popenargs, **kwargs).wait() File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 710, in __init__ errread, errwrite) File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 1335, in _execute_child raise child_exception OSError: [Errno 2] No such file or directory
