I'm very new to houdini, and I'm having trouble understanding how to create special attributes and groups in my digital asset. I've been searching the docs and doing google searches, but I can't seem to find information on this topic.
This is the link to the docs:
http://www.sidefx.com/docs/unreal/_attributes.html [www.sidefx.com]
Can someone help me or point me towards some good examples?
Thank you in advance :-)
How do I create special attributes and groups?
1813 1 1- ryanagogo
- 10 posts
- Aladin Sane
- 67 posts
ryanagogo
You use the attributecreate node and put in the correct name and data setup based on the document you linked.
First image below shows a couple of these nodes in a tree.
The second image shows inside one of the nodes on how it was setup.
Just in case you need to know, the unreal_material value in the String field is obtained by using copy reference if you right click on your material in Unreal Editor.
Hope this helps.
Edited by Aladin Sane - Feb. 23, 2018 06:31:17
