Hi!
I'm using a point function on a resampled line and the result is always zero. Can you guys tell me what I'm doing wrong?
f@xyz = @P.x + @P.y + @P.z; //to get a different float value per point
float seed = point(0, “xyz”, 0); //to pick a different value to use in a rand function later
f@Check = seed; //when I check in the spreadsheet, I get 0 at every point…
point function troubleshooting
1894 4 0- olivierth
- 1007 posts
- tamte
- 8551 posts
olivierthf@xyz = @P.x + @P.y + @P.z; //to get a different float value per point float seed = point(0, “xyz”, 0); //to pick a different value to use in a rand function later
first line: sets value of f@xyz of the current point in the current geometry
second line:
point(0, “xyz”, 0);
takes value of xyz attrib from the first input, not the current geo, therefore if xyz attrib was 0 before it will get 0EDIT: unrelated to the particular issue, you may get better random number if you base it on vector v@P directly instead of jumping through hoops to unnecessarily compute float seed from vector, so just do
float rand = rand(v@P);
Edited by tamte - April 9, 2018 14:51:14
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- olivierth
- 1007 posts
Hi tamte,
I'm not sure I understand the part: “takes value of xyz attrib from the first input, not the current geo”. Isn't it taking what's connected in input zero of the wrangle (0,1,2,3), to verify the xyz value of the point number 0?
What would be the right way of getting the xyz value of the point 0? (the result should be 0.4 according to the geometry spreadsheet)
-Olivier
-Olivier
- Aizatulin
- 475 posts
It is taking only what is created before.
So one possible solution can be creating another wrangle before, where you create the xyz attribute and after this you can read this out the way you did.
Or you read out the point attribute ‘P’ for the point zero and calculate the xyz as local value from a function.
- olivierth
- 1007 posts
