Flickering on animation
2579 7 1- Island
- 340 posts
- Island
- 340 posts
I was partially able to solve this, but I don't know why this is so much more complicated than Cinema 4D's sweep nurb. In C4D, a sweep allows spine control (for varying thickness) easily, creates UV's automatically, and doesn't have to do strange things like start with an open circle of 359 degrees and exchanging U and V coordinates to avoid ugly seams. If one adds a polycap, it creates ugly renders like above. I have to select the end loop and create groups to have it behave properly. Here is a fix with notes to show the issues and an updated file. Please, SideFx, make this easier - if you want to market Houdini to modelers.
Attachment Not Found
Edited by Island - April 20, 2018 21:47:07
- matthias_k
- 483 posts
You have to distinguish between point and vertice attributes.
Usually it is better to have the UV attribute as vertice attribute,
because shared points, like your “begin/end” point will try
to share the same UV coordinate if UV is assigned as point attribute.
If you do not like to repeat creating all the nodes,
you can create an digital asset :-)
- Island
- 340 posts
That is VERY helpful. Rotating one Uv texture -90 degrees made the need to map v coordinates from u coordinates not necessary. The digital asset idea will make this process easier and I liked that your method doesn’t require a 359 degree open arc and adjusting the fuse distance.
Is there a way in uv transform to put in an expression that scales the y axis by arclen circle divided by arclen curve?
- matthias_k
- 483 posts
arclen("../" + opinput(".", 0),0,0,1)
should give the length of the first input, which can be used to scale the UVs.
“arclen spline” in the “texture type” select should do the same…
(but not working here)
Edited by matthias_k - April 23, 2018 03:13:26
- Island
- 340 posts
- matthias_k
- 483 posts
:-) many thanks
arclen:
http://www.sidefx.com/docs/houdini/expressions/arclen.html [www.sidefx.com]
opinput in action:
http://www.sidefx.com/docs/houdini/expressions/opinput.html [www.sidefx.com]
arclen("../" + opinput(".", 0),0,0,1) is same as: arclen("../NodeToGetValueFrom",0,0,1) which one to choose, depends on your needs
arclen:
opinput in action:
Edited by matthias_k - April 23, 2018 11:44:25
- Island
- 340 posts
