I am trying to retime an animation based on a point attribute but the retime SOP does not seem to work when is inside a for loop. Are there some limitation in the retime sop I need to know?
Bests,
Nico.
Well, I actually found a solution of a kind but is very slow…
Basically I run the retime on every object and delete all but the one I would like to keep. I really don't understand why the same solution do not work by fetching each object individually. Attached is the hip file.
why h17 retime does not seem to work inside a for each loop.
2377 3 2- Nicolas Heluani
- 280 posts
- tamte
- 8554 posts
- Nicolas Heluani
- 280 posts
tamteWow, thank you very much, that explains it very well.
https://www.sidefx.com/forum/topic/53471/#post-240925 [www.sidefx.com]
Thanks.
- Nicolas Heluani
- 280 posts
mmm….
Now I have a weird issue with file caches.
If you save the file After the for loop the size of the bgeo.sc is gigantic. like if the geometry remains there even though you delete it inside the for loop…
Very strange….
Edit: Indeed it was exactly that. The packed fragments actually contain the whole geometry so for each loop I was multiplying my own geometry. I solve the problem by unpacking and packing again everything after the operation but SideFX support actually recommend me a better system by just using a repack node with “Repack Fragments” after the blast.
Very strange….
Edited by Nicolas Heluani - Oct. 15, 2018 20:06:07
