MMB transform without clicking the handle
   1558   3   1
Please, there used to be this feature:
While in the Transform or Scale mode, you can move or scale along the X,Y and Z axes without actually having to click on the tool.
Simply MMB click and drag anywhere within the viewport and move it towards the direction you wish to go to.
As shown here: https://youtu.be/5HtNcD2mrJY?t=41 [youtu.be]
When scaling, it works fine for me … but moving is not bound to an axis. Was this feature completely abandoned? Or could I turn it on by any settings?
If I recall correctly, it was dropped in favor of a uniform scale because the binding of mouse axis to scale axis didn't work well and was difficult to control.
Perhaps it will return in the future if the developers figure out how to make it work satisfactorily.
It can be set in Preferences -> Handles Allow Indirect Handle Dragging with MMB: Translate Handle -> Map Drag to Axis
(by default it seems to be set to Construction Plane)
Edited by jandress - Oct. 19, 2018 15:35:08
Thank you both VERY much!
