Particles with motion blur?
9695 5 1- sascha
- 158 posts
- jesta
- 311 posts
- sascha
- 158 posts
- wolfwood
- 4262 posts
sascha
Thanks, the Velocity Attribute Blur does work.
By the way what does this warning mean?
Warning: topology for /obj/particles: and /obj/particles: doesn't match - no deformation blur will occur
For deformation blur to work you need to have matching topology. (The geometry can be deformed but it needs to have the same point/face counts etc.)
In cases where your particle systems have changing point counts deformation blur won't work.
- sascha
- 158 posts
- Serg
- 511 posts
afaik mantra doesnt support multisegment motion blur like Renderman or MentalRay etc… which is a real bummer.
Imagine a fast spinning wheel… a point on the wheel may be in one position in one frame and a completely different position the next, with uni-segment motionblur the wheels would appear to shrink because the point is being blured in a straight line from one side of the wheel to the next, the problem increases the faster the wheel spins. If the wheel is moving forward as well as spinning it will start doing even weirder things.
With multi-segment motion blur the renderer takes more than one time sample, i.e. it reads the position of the point several times in between frames, thus aproximating a radial blur.
Sesi should really address this in a near future update… I dont know of any renderer apart from mantra where you cant render spinning wheels!
but perhaps this can be manually hacked to mimic multisegment blur, i.e. choose how many segments you want, render the shot multiple times (only for the element that requirers it) , starting from different interframe times then blend them all together…. maybe
