… or primitives in general.
Is there a way to control ray visibility on a primitive level?
Jon
vm_rendervisibility behavior on packed prims?
1557 8 0- jpparkeramnh
- 178 posts
- tamte
- 8554 posts
- jsmack
- 7770 posts
- jpparkeramnh
- 178 posts
- tamte
- 8554 posts
here is a simple example of Scene level stylesheets that target primitives of specific objects
file has 3 Styles:
1. targets just a single primitive of boxes object by primnum
2. targets just a single primitive of boxes object by name attribute
3. targets all primitives of spheres object and uses myrendervisibility attribute value to set vm_rendervisibility property directly
while this is using scene level MS definition, you can attach MS to an object in many different ways
- adding shop_materialstylesheet with MS JSON string directly to an object (possibly material too? not sure)
- creating primitive attribute material_stylesheet with MS JSON string on your geo
- maybe some other
but regardless, scene level MS can target your specific SOP geo so there should be no need to use other types of assignments just to get that functionality
file has 3 Styles:
- maybe some other
Edited by tamte - May 16, 2019 12:03:56
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- jpparkeramnh
- 178 posts
- tamte
- 8554 posts
jpparkeramnhthen try storing it in material_stylesheet attribute, I haven't tried using it, but in theory it can maybe be detail attrib and in that case maybe you don't need the object target in the json, just the prim targets
Thanks for the example Tomas!
I'm packing multiple geo types into a SOP asset and want the asset to carry the visibility settings with it, hence the SOP-level request.
Jon
or then maybe individual material_stylesheet attribute per prim with it's own stylesheet definition of rendervisibility property
Edited by tamte - May 16, 2019 14:36:24
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- tamte
- 8554 posts
here are 2 examples of geo level assignments
1. assigned as detail material_stylesheet attribute, still requires myrendervisibility prim attribute
2. assigned as prim material_stylesheet attribute, fully describing the visibility settings per prim
but overall the stylesheet definition is the same as scene level
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- jpparkeramnh
- 178 posts
Tomas,
Thanks! I forgot to reply back and let you know that I did exactly what your example shows and it works great!
I haven't used style sheets (at all, really) until now and always assumed they carried the same limitations as trying to apply object-level overrides via a primitive attribute. Apparently you can apply render overrides with style sheets that you can't any other way, which actually gets rid a lot of limitations I've run up against. Cool!
Jon
Jon
