I'm trying to get the point numbers for primitive groups. This doesn't seem to work as Houdini's definition for pointlists is too narrow and it will only list by point groups.
Converting all my primitive groups to point groups isn't possible either because the group
SOP doesn't support wildcards and I have a shitload of primitive groups.
Trying to create an attribute string that I can use in a partition SOP doesn't seem to lead anywhere as I can't seem to create an attribute by group because it doesn't look like houdini can tell be which group my geometry is a member of.
Anyone have any ideas how i can get around this?
Cheers
Jerry
primitive groups > point groups
5338 4 0- jesta
- 311 posts
- goldfarb
- 3455 posts
- jesta
- 311 posts
cheers mike. doesn't help much unfortunately
My problem is I have 123 primitive groups and i need to be able to identify the points in each group. Also I want the option of changing the number of points in general.
It's part of a script I'm running that loops through each group, finds the point numbers and loops through those to give me some arbitrary data.
The problem is the pointlist or pointgrouplist function only accepts point groups as a definition of the points to list. grrr
I was hoping a solution similar to yours would be able to stick my group names into and attribute that i might then use to recreate my groups using a partition SOP but so far it's all proving a little elusive.
could be due to too much egg nog, or i hit a wall in hscript.
I'm almost looking at adding a section to the script which adds a group SOP and switches the groups from prim to point to do it that way. I just thought it would be easier.
- goldfarb
- 3455 posts
- jesta
- 311 posts
