Why is Houdini constantly making decisions for me?
   21723   72   2
BabaJ
It's not that the ‘problem’ is not seen; It's that there is no problem.
I don't know a single creative artist who would look at taking up scripting in Python or VEX as desirable.
The reason why tools like MOPs and GDT are so well liked is because they bring an intuitive and creative workflow to the artist in a way that feels like a natural extension of their artistic workflow.
The real ‘problem’ is that an app like Houdini attracts a lot of technicians, who then tend to respond to calls for a more intuitive interface with the quote above..because they don't get it.
Thankfully, from what I've been able to ascertain in the past couple of years, SideFX gets it. Guys like Mike Lyndon, Paul Ambrosussien and Luiz Kruel really get it, and they're driving innovation at SideFX with new intuitive tools with the artist in mind.
I think the future is bright!
>>Kays
You do now.
The only problem is some artists make too many assumptions about other artists. Which is really what the implied original point of my post in this thread was.
BabaJ
You do now.
I don’t know a thing about you or what you do. How about some links? :-)
Edited by Midphase - Sept. 4, 2019 12:43:19
>>Kays
I would gladly continue this conversation privately if you actually have anything of value to contribute.
And I suggest that is the best approach as we have both contributed to this post on our views, and to continue to do so in this forum is a waste of peoples time and becomes off topic.
BabaJ
Does anyone have to be overly presumptuous to think that no one likes to press T (or E/R) twice in order for the tool to switch to the new selection? Do you personally like the results you get with the PolyBevel? I could go on with many others.
There are (basic) things in Houdini that are broken and have not been addressed, even after reporting them, which I think makes the preferences discussion kinda moot at this moment. That is, unless someone's prepared to state that they prefer things that are demonstrably broken.
Wrong question…the point was about ‘it’ being a problem and assuming other artists have the same issue.
But to answer anyway ref press T, E/R and PolyBevel…I don't know if I ‘like’ it or not, as I have made my own tools to accomplish what I want and have no need for that process/sop.
But also to note..there is a big difference between ‘like’ and ‘problem’.
Don't like? RFE.
RFE doesn't happen? Do something else. No problem.
There's no “problem” outside consciousnesses, inside which all “problems” are a sub-specie of “likes”. But if we got to the point of having a discussion bordering on Epistemology, Logic and Philosophy of Mind, I'm tapping out - need to finish modeling the prop I'm working on for more RFEs.
pickled
I'm with you Pickled…conversations like these always turn sour after the “why don't you code your own SOPs” curmudgeons start waiving their walking sticks at the lazy kids!
>>Kays
If the Game Dev team could affect the viewport workflow then we would quickly see improvements, but I believe its out of their purview.
Where is the user-viewport centric dev team these days
BabaJ
As it was mentioned somewhere, the majority of users concentrate on the nodes and networks, on pipeline tools, vex and al the other TD stuff. They often don't even see the problem.
It's not that the ‘problem’ is not seen; It's that there is no problem. It really depends on the person, not across the board for everyone.
And this is exactly not seeing the problem. Thanks for making my case.
It is a common response to posts like mine: “It's all subjective”.
No, it's not.
Using a feature or not is a subjective decision. Liking a feature or function or not is a subjective matter.
Not being able to use a very common function because it doesn't exist is an objective flaw.
Having to do three times as many actions for the same very common task to achieve the same result like in any other software with this function, is objectively slower and a drawback.
That is a problem. And the problem with Houdini is, that until recently, it was only used by a very small user base with a very narrow focus on some specific things where a lot of what is being complained about now, didn't matter. So for a long time many of the issues actually weren't a problem because no one really compared Houdini with other DCC apps. I have again to point to the view port normals. Houdini users were used to work with a geometry display that looked like some early 80's Gouraud realtime shading up to version 16 (?). No one cared about it. People even defended it when I came and pointed it out.
And since SideFX has been living and working with exactly those users for a long time, they failed to develop a sense for certain problems as well. This creates what you call an Echo chamber. Long time Houdini users often seem to be feeling that every complaint coming from new users with experience in other software is an attack on their very own work environment.
I am not saying this to offend anyone. I am saying this to analyze the source of the fact that Houdini is matter-of-factly and completely objectively far behind other software in terms of basic UX.
It has the most elaborated methods of working with a node tree but the most rudimentary means of organizing and managing hundreds of objects. It has sophisticated shelf tools that can set up a complex ocean sim for you in seconds, but if you want to simultaneously edit the geometry of two objects in two different hierarchies (possible even in blender now) your lost. It has a very clever UV unwrapping toolset, but if you want to see the UV screen and the Geo side by side you can not drag the viewport divider to make one or the other view smaller or larger. This is Lightwave 15 years ago.
There are objective short comings in Houdini that have nothing to do with personal preferences.
I have no issues of adapting to certain workflows that may be different to what I am used to. I haven't even changed the hotkeys for Translation/Scaling/Rotation, which are not industry standard in Houdini. But I refuse to use a 3Key combination for something a common and most frequently used as a viewport interaction because it objectively slows me down and interrupts my workflow - no matter how good I memorize them. I can not even change the key assignment because that extra redundant navigation mode seems to be hard coded and when I try to change it it breaks a lot of other things.
If you talk about subjective preferences then you have to talk about choice. I am complaining about the things where we don't have one.
Edited by OneBigTree - Sept. 5, 2019 11:03:59
pickled
BabaJ
I agree with you Pickled, does anyone enjoy the Curve SOP in Houdini? It's so hard to use compared to Cinema4D's Curve tool.
Here is another simple example.
When you are modelling something in smooth shading, like a car for example, where you really need to see if the surface is smooth and even and you go into any component selection mode, you don't see your components, like edges and faces. You have to actively turn the edge display on and off to evaluate your work. In literally every other DCC app that is sold for modelling you get the components displayed as soon as you go into any components selection mode.
This is symptomatic for Houdini. It is neglecting the amount of time the user spends dealing with avoidable UI interactions. Admittedly, it doesn't make much difference if you are doing a sim that takes hours anyway. But it does matter, and all those little things sum up believe me, if you have to do some modelling on a tight schedule. And most of all these things constantly interrupt your workflow and force you to think about things you shouldn't think about. A good UI/UX gets out of your way as much as possible.
I sent a video to SideFX reporting these issues and a related bug almost two years ago: https://www.youtube.com/watch?v=EtDlQQ4dowA [www.youtube.com]
the second image is showing the bug I reported. It is still there in the latest production build. When you go to point selection mode first in a selected object, points are not shown, no matter what shading mode you're in. You have to switch to edge or primitive and then back to show the points.
Edited by OneBigTree - Sept. 6, 2019 10:38:26
what is wrong here.JPG (176.2 KB)
no point.JPG (81.5 KB)
EricSheng
pickled
BabaJ
Houdini is the only software I know where you have to delete something to get a simple closed curve.
OneBigTree
I too have reported this to Support, before 17.5.
It's either a well founded reason for why it is so, which we're not privy to, or another case of not enough people caring, be they at sesi or in the user-base.
Either way, I find this to be towards the bottom of the list on things to be fixed asap.
Edited by anon_user_89151269 - Sept. 6, 2019 16:59:49
Guys, it's called “view”port for a reason. Touching it is considered impure in Houdini land!
OneBigTree
You can't select points at the object level - you can only select objects. If you had the sphere selected when you want into the point selection mode, it would have dived into that object and then you can select points. But when you have no object selected, Houdini has no idea which object to select points on. This is probably a good case for an informative prompt.
Just a quick thoughts before I read the whole:
  • Houdini isn't a modeling DCC, it's better to try Blender. Just check the recent additions in 2.81 beta (@pablodp606 on Twitter).That is something promising, and in terms of UI/UX, it is already at a different level…
  • I guess the selection mode buttons are mostly for incoming Maya users, it's better to use nodes and the dive in/out commands.(However there is an important switch in the component mode button's menu: Show Display Operator/Show Current Operator. )
  • Be my guest in this topic: UI/UX: Share your screenshots & tips & tricks & ideas [www.sidefx.com]
artstation.com/scivfx
twod
OneBigTree
I don't know how to connect your answer to what OneBigTree said.
His point, in essence, is that when you dive into a sub-component mode, Houdini should automatically go into “wire shaded”. All the 3d programs that I know, don't even have a “non-wire shaded” mode when into sub-object mode, i.e. edges/wires are always visible.
Now, I don't agree with OneBigTree's grievance (there are cases when you're in component mode and don't want wires, like high polycount meshes and working on them at sop lvl), I'm just confused about your answer which seems to miss the mark completely.
Edited by anon_user_89151269 - Sept. 6, 2019 20:43:50
pickled
Thinking in bg about this, I figured it might also be the reason why points are not shown, when you first dive into this mode. But then, why are they shown when returning from edge/faces back to points…
Anyway, these are not the most pressing issues IMO. The bevel, the snapping, local transformations and other poly modeling sops that are missing features or are awkward to use if not downright broken should get the most immediate attention.
The confusion lies in that OneBig is saying there are 2-3 problems and twoD is answering one of them.
In regards to the issue that twoD is replying to, you can see the points will display when you use the I key to dive in the a sphere but the points wont display if you press 2 on the keyboard from the scene level.
