Ocean Flat Tank, how to make a lake?
2095 2 1- iskan
- 18 posts
- kemijo
- 88 posts
In most cases you would use an ocean spectrum on a flat grid that has been cut or modeled into the shape of the body of water that you want. The ocean spectrum is a deformer that will give you body-of-water type motion without needing to run a simulation. You would use a FLIP sim tank setup if you also want water interaction, like a boat wake or splashes. Check these out:
https://www.sidefx.com/tutorials/deep-dive-into-ocean-spectrum-node-in-houdini-1/ [www.sidefx.com]
https://www.sidefx.com/tutorials/infinite-ocean-effect-with-flip/ [www.sidefx.com]
/ken_jones/$: _
- iskan
- 18 posts
