Recently we changed the default start sequences from 1 to 1001, but every time we start up Houdini, the animation range is correctly set to 1001 and the frame cursor is set to 1.
How do we change the frame cursor from it's default value, so that it also on start up is set to 1001?
Kind regards,
Chris
Houdini start up; start frame
9522 13 1-
- Klonkel
- 79 posts
- BabaJ
- 2171 posts
- jsmack
- 8188 posts
- Klonkel
- 79 posts
@BabaJ
With frame cursor I actually meant the current frame. Yes the frame range is set and applied to 1001 to 1240, but every time houdini has started up the frame range is correct, from 1001 to 1240, but the first frame is set to 1, until I do ‘ctrl + upArrow’, then it snaps to 1001.
@jsmack
Do you know where I could find a startup script, or how to set this?
@jsmack
- BabaJ
- 2171 posts
@BabaJ
That's odd, must a bug for your current version. If you don't need to work with the current version you might want to try a more a recent version or even try your current version but with a different hip to see if it gets repeated; possible it's only your current hip that is glitched. Otherwise, bug report.
- Klonkel
- 79 posts
BabaJ@BabaJ
Just tried it with our previous houdini version; 17.5.425, changed the startup time range to 1001, but still the first frame is after the startup set to 1 instead of 1001?
- jsmack
- 8188 posts
KlonkelBabaJ@BabaJ
How are you changing the start frame in the first place? Don't you need a custom startup script for that?
- dzigakaiser
- 17 posts
I think he is just setting start and end in the global animation options and saving it as default. I just tried it and this indeed makes a new scene be set to 1001 - 1240 while having 1 as the current frame.
Startup script would be the way to go, though to be fair, it would be expected behaviour of Houdini to be on the first frame of the range on startup.
Houdini 18.0.348
Houdini 18.0.348
Edited by dzigakaiser - Feb. 21, 2020 11:06:44
freelance matte painter & environment concept artist
- BabaJ
- 2171 posts
Houdini 18.0.348
That's odd because I am using 18.0.348 too and my first frame starts at the default start frame of 1001 (for the hip with range set to 1001 - 1240).
My bad though, I think the op meant for all hip files which is why jsmack suggested a script. Default range set in a hip stays only with that current hip, not accross the board for other hips.
- jsmack
- 8188 posts
- dzigakaiser
- 17 posts
jsmackYes, I also think that is what OP meant^¬^ And I just thought that if you click “Save as default” in the global animation options and the future files do have the frame range set correctly, then they should maybe also have their current frame set to the start of this range and not to 1
Yeah, I thought you meant changing the start range for all future scenes.
- jsmack
- 8188 posts
- dzigakaiser
- 17 posts
@jsmack:
Yeah, same ^.^
@Klonkel:
The easiest way would be to go to your Houdini user folder and create a “scripts” folder. In there you simply create a 123.py file with this content:
*Edited the code since I found a cleaner example from jsmack and xjorma here: Set range thread [www.sidefx.com]
If you use Houdini Core, the script needs to be called houdinicore.py.
Info about the start up scripts here:
Docs Python Script Locations [www.sidefx.com]
Take care,
Dziga
Yeah, same ^.^
@Klonkel:
#Houdini startup script import hou start = 1001 end = 1240 hou.playbar.setFrameRange(start, end) hou.playbar.setPlaybackRange(start, end) hou.setFrame(1001)
Take care,
Dziga
Edited by dzigakaiser - Feb. 21, 2020 16:42:14
- Klonkel
- 79 posts
