how to render .exr file with passes?
5186
6
2
ykcosmo
March 21, 2007 1:12 a.m.
is there any way to render exr file with passes? such as normal, diff, amb, reflection, shadow?
^_^
old_school
March 21, 2007 5:24 a.m.
Not in Houdini8.
JColdrick
March 21, 2007 8:57 a.m.
However, you can render out layers to separate exr files, we do that all the time.
And as Jeff teases, you can't render multi-layers in one in Houdini *8*.
J.C.
John Coldrick
old_school
March 21, 2007 4:05 p.m.
symek
March 21, 2007 4:33 p.m.
These small secrets of you, guys… :wink:
ykcosmo
March 25, 2007 10:17 p.m.
how to render out layers to separate exr files? ^_^ I tried to enable it under deepraster tab, but the exr files are all 0kb…..
^_^
JColdrick
March 26, 2007 10 a.m.
Works for me. Apart from setting the bit depth to half-float, these layers are what you get as default once you set your output image to “exr” and add some popup layers. Cheers, J.C.
LayerTest.hip (152.3 KB)
John Coldrick
