Make this python code working with python 3
2290 12 3- vinyvince
- 255 posts
Hi guys
Might i ask you what might cause this python 2.7 code not to work with v3 please? How to fix it?
Looking forward to hear what you python's guru has to suggest, thanks!
v*
import numpy as np
node = hou.pwd()
geo = node.geometry()
ptsString = geo.pointFloatAttribValuesAsString("P") # get pts data efficiently
ptsArray = np.frombuffer(ptsString, dtype=np.float32) # convert to np array
ptsArray = ptsArray.reshape(len(ptsArray)/3 ,3) # reshape as array of vectors
mean = np.mean(ptsArray, axis=0) # compute mean of pts positions
ptsArray = ptsArray - mean # transform pts to the center
mtx = np.cov(ptsArray.T) # compute covariation mtx
eigenvalues, eigenvectors = np.linalg.eig(mtx) # compute eigens
# sort eigenvalues
sort = eigenvalues.argsort()
eigenvalues = eigenvalues
eigenvectors = eigenvectors
e1 = eigenvectors
e2 = eigenvectors
e3 = eigenvectors
# compute bbox dimesions
orient = np.array( (e1, e2, e3) ).T
ee1 = np.dot((1,0,0), orient)
ee2 = np.dot((0,1,0), orient)
ee3 = np.dot((0,0,1), orient)
scale1 = np.dot(ptsArray, ee1)
scale2 = np.dot(ptsArray, ee2)
scale3 = np.dot(ptsArray, ee3)
scale1 = ( np.amax(scale1) - np.amin(scale1) ) / 2
scale2 = ( np.amax(scale2) - np.amin(scale2) ) / 2
scale3 = ( np.amax(scale3) - np.amin(scale3) ) / 2
scale = (scale1, scale2, scale3)
# output to attribs
geo.addAttrib(hou.attribType.Global, "eigenvector1", (0.,0.,0.))
geo.addAttrib(hou.attribType.Global, "eigenvector2", (0.,0.,0.))
geo.addAttrib(hou.attribType.Global, "eigenvector3", (0.,0.,0.))
geo.addAttrib(hou.attribType.Global, "scale", (0.,0.,0.))
geo.addAttrib(hou.attribType.Global, "mean", (0.,0.,0.))
geo.setGlobalAttribValue("eigenvector1", e1)
geo.setGlobalAttribValue("eigenvector2", e2)
geo.setGlobalAttribValue("eigenvector3", e3)
geo.setGlobalAttribValue("scale", scale)
geo.setGlobalAttribValue("mean", (float(mean), float(mean), float(mean)))
v*
import numpy as np
node = hou.pwd()
# sort eigenvalues
e1 = eigenvectors
e2 = eigenvectors
e3 = eigenvectors
# output to attribs
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
- tamte
- 8556 posts
in Python3 this line
should look like this
to enforce integer division which in Python2 was happening automatically
also if you are using this code to compute oriented BBox of the geo or transform matrix from it, then you may consider using Extract Transform SOP instead
PS: try to embedd any code in code blocks, otherwise you will lose all formatting and
ptsArray = ptsArray.reshape(len(ptsArray)//3 ,3) # reshape as array of vectors
symbols
Edited by tamte - Sept. 18, 2021 13:22:13
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- vinyvince
- 255 posts
Thanks you so much Tomas. Yes, you guess right, it's to compute an bounding box more correctly oriented than the one compute by the default Houdini sop node . See below
Im interested by your suggestion actually, Do you mind to tell me a few more detail how to use this node to output an oriented bounding box please?
Thanks you!
Thanks you!
- vinyvince
- 255 posts
Ahh, some issues still remains, i put the full code in the python clock code in case you might have one idea , should be more easy to track .... Any idea guys? Tomas?
import numpy as np node = hou.pwd() geo = node.geometry() ptsString = geo.pointFloatAttribValuesAsString("P") # get pts data efficiently ptsArray = np.frombuffer(ptsString, dtype=np.float32) # convert to np array ptsArray = ptsArray.reshape(len(ptsArray)//3 ,3) # reshape as array of vectors mean = np.mean(ptsArray, axis=0) # compute mean of pts positions ptsArray = ptsArray - mean # transform pts to the center mtx = np.cov(ptsArray.T) # compute covariation mtx eigenvalues, eigenvectors = np.linalg.eig(mtx) # compute eigens # sort eigenvalues sort = eigenvalues.argsort()[::-1] eigenvalues = eigenvalues[sort] eigenvectors = eigenvectors[:,sort] e1 = eigenvectors[0] e2 = eigenvectors[1] e3 = eigenvectors[2] # compute bbox dimesions orient = np.array( (e1, e2, e3) ).T ee1 = np.dot((1,0,0), orient) ee2 = np.dot((0,1,0), orient) ee3 = np.dot((0,0,1), orient) scale1 = np.dot(ptsArray, ee1) scale2 = np.dot(ptsArray, ee2) scale3 = np.dot(ptsArray, ee3) scale1 = ( np.amax(scale1) - np.amin(scale1) ) / 2 scale2 = ( np.amax(scale2) - np.amin(scale2) ) / 2 scale3 = ( np.amax(scale3) - np.amin(scale3) ) / 2 scale = (scale1, scale2, scale3) # output to attribs geo.addAttrib(hou.attribType.Global, "eigenvector1", (0.,0.,0.)) geo.addAttrib(hou.attribType.Global, "eigenvector2", (0.,0.,0.)) geo.addAttrib(hou.attribType.Global, "eigenvector3", (0.,0.,0.)) geo.addAttrib(hou.attribType.Global, "scale", (0.,0.,0.)) geo.addAttrib(hou.attribType.Global, "mean", (0.,0.,0.)) geo.setGlobalAttribValue("eigenvector1", e1) geo.setGlobalAttribValue("eigenvector2", e2) geo.setGlobalAttribValue("eigenvector3", e3) geo.setGlobalAttribValue("scale", scale) geo.setGlobalAttribValue("mean", (float(mean[0]), float(mean[1]), float(mean[2])))
- tamte
- 8556 posts
vinyvinceit really depends on what you are doing as it doesnt compute best fitted oriented bounding box, which would be also unstable per frame
but it will compute rigid transform difference between 2 geos withthe same topo so you can use that to update either bbox from rest or initial best fitted oriented bbox
here is and example:
- red - oriented bbox recomputed every frame using Bounds SOP - unstable as it soely depends on input geo per frame
- green - oriented bbox computed only on 1 ref frame and then updated its transform based on geo difference
- blue - axis aligned bbox computed from the geo at rest, so precise user controlled stable box alignment and then transform updated every frame based on geo difference
Edited by tamte - Sept. 19, 2021 17:14:02
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- tamte
- 8556 posts
vinyvinceseems to work for me as far as Python3 syntax and that it doesnt error out, except for line
however I can't speak to actual values it outputs
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Aizatulin
- 475 posts
- vinyvince
- 255 posts
Both are brillant answer, thanks you guys, you both deserve a medal for all the constant contribution
Tomas, . I learned new things thanks. Actually my main target at this moment, is trying to creat the most accurate oriented bounding box for piece with arbitrary possibly intriguate shapes, which mean i ignore the rest position.
Many thanks to both of you guys!
vincent
vincent
- vinyvince
- 255 posts
Hello everyone
Strange, it was working fine in build 8.5 696, and now i got Python errors once again
"Error
Python error: Traceback (most recent call last):
File "<stdin>", line 43, in <module>
AttributeError: 'map' object has no attribute 'sort'" on the first python node of the above hip file...
Is it my station or is it working for you?
"Error
- Aizatulin
- 475 posts
- vinyvince
- 255 posts
You did my day man, thanks you you so much Aizatulin! big hug and a virtual (sanitized) beer for you
Im curious why this change. Oh people has to modify their own python tool for every 3 release, will not be hard to follow ?
- Aizatulin
- 475 posts
- vinyvince
- 255 posts
Yes, i also just notice i have to update some snipest in COP for my substance houdini edge wear .
Hopefully it will not happen not too often!
thanks again
thanks again
