Getting to work with the help of medical illustration professional to create new anatomic models from DICOM volumes.
Sure you can get them in Houdini, but wanted to ask if will be possible once I converted them in solid, if will be possible to add on the solid interior a volumetric 3d texture (i.e. a tissue), instead of just painting a surface.
In this way if I cut them I will be always able to see the right thing, and not an empty shell.
Volumetric 3D texturing
1597 6 1- davide445
- 54 posts
- Konstantin Magnus
- 670 posts
Hi Davide,
best you provide some data.
- traileverse
- 355 posts
davide445
Maybe try using tetrahedrons instead and then convert to polys. When u cut the tet mesh you’ll have solid interior.
hou.f*ckatdskmaya().forever()
- davide445
- 54 posts
Just to have an example let's say I want to import Ircadb 1.12 [www.ircad.fr] patient DICOM file, transform in solid one of the kidneys and next my goal will be to fill the volume with a 3D texture containing the tissue details such as in this example
https://histologyguide.com/slideview/MH-143-kidney/16-slide-1.html?x=13531&y=24200&z=75.0 [histologyguide.com]
AMD Ryzen 5 2600X, 4x16GB 3200 Mhz, Kfa2 GTX 1070 EX 8GB, Windows 10 Pro, KDE Neon
- Konstantin Magnus
- 670 posts
Cant read those files, but if its slice images you could look into this thread:
https://forums.odforce.net/topic/41022-convert-slice-images-to-volume/ [forums.odforce.net]
- davide445
- 54 posts
- jsmack
- 7771 posts
