Join Primitives
   1210   4   1
I am sure there is a simple answer, but ive been trying for hours to Join/Merge/Connect/Glue/Combine Primitves together that are touching each other on the edges and to form a new, single primitve out of them.
In the pciture you see 13 surfaces (or primitives?) that i want to combine to only one surface.
I Tried with the "Join" sop, but it only gives me white borders no matter what i click
Any help will be greatly appreciated!
Screenshot 2022-01-04 233115.jpg (148.4 KB)
first Fuse SOP to make sure all your prims are connected
then Divide SOP and check Remove Shared Edges
FX Supervisor
Method Studios, NY
It worked, thx! Not very intuitive though
Eastwood
For intuitive, try the dissolve tool.
Select the edges you want to remove, then hit 'delete' to dissolve the edges.
if you want one node which is an OTL anyway try the lab "extract silhouette" trace axis Y
