General lighting questions
1634 12 1- Sybaris
- 41 posts
Hi everybody,
I'm playing around with Karma and lighting. In the following scene I'm using a dome light only which I set to intensity 4. It's pretty close to what I want but too dark in the shadow areas.
What is a general lighting setup for outside scenes (this actually is an outdoor scene)? Should I add a distant light or increase the intensity of the dome light? Could you point me to some document or video?
Thanks in advance!
Regards,
Günther
Thanks in advance!
Regards,
Günther
- Enivob
- 2539 posts
- Konstantin Magnus
- 670 posts
Hi Günther,
I once recorded these breakdowns:
https://youtu.be/zlCTJkf150Q [youtu.be]
https://youtu.be/an-0Cfhazj4 [youtu.be]
- Sybaris
- 41 posts
Hi Konstantin, Hi Enivob,
My first mistake was probably that I treated this as an outdoor scene although it is actually an indoor scene. That obviously comes from the fact, that I always see the building from the outside – pictures attached. (This is the Rotunda in Vienna, built 1873 for the world fair, burned down 1937.)
Thanks for the input! I’ll try a couple of things and come back with results.
Regards,
Günther
Regards,
Günther
- Sybaris
- 41 posts
So, this is the first try - acually a pretty simple approach. I placed two sphere lights - one right in front of the camera, the second in the back, with a big radius and low intensity. That already looks a lot better.
@Konstantin: I tried to translate to Houdini what you are doing in the C4D video, but I failed because I don't know how to, for example, create an "Aura". I simply don't know enough about Houdini atm.
Btw: is it only possible to place lights at the highest geo level? I would like to place lights anywhere. If I move a room for example, I’d like the lights to move too. Is there a way to achieve that?
Günther
Günther
- Sybaris
- 41 posts
Second try.
@Konstantin: Inspired by your video I've put area lights right before the windows, a little smaller than the windows, lifted up a bit and with an intensity of 10 (that's probably a bit overdone).
But that looks even a bit better than the one before.
@Enivob: I tried that in the very beginning but the problem was, that, if I put the distant light and the dome light in the same direction, the dome light can't really brighten up the shadows because it's blocked by the same objects as the distant light.
If I put the dome light at a different angle, then I get sort of two shadows...
Did I miss something?
Günther
Günther
- Sybaris
- 41 posts
- Sybaris
- 41 posts
- willh
- 134 posts
- willh
- 134 posts
- willh
- 134 posts
- Sybaris
- 41 posts
- Sybaris
- 41 posts
OK, here are the results.
The first pic ist the version with the area lights before the windows. The second one only has one dome light with an intensity of 4 and an exposure of 2.
I guess, I have to play around with all those buttons to find a decent look. But I like both, the first one is softer, the second one is more realistic. And the second produces a lot of noise. I've tried the same approach with different scenes and the effect is always the same: one single dome light with exposure produces pretty much noise. That can be removed with the denoiser or by tweeking those millions of settings.
Anyway, thanks willh, for the input!
Günther
Günther
