Im testing Solaris and Karma before it gets used in production.
Im noticing a difference in the specular/normals when I use displacement.
Its just a megascans material with Albedo,Roughness,Normals and Displacement maps.
True displacement on with dicing 0.5.
Also with XPU, what is the VRAM load?
Load Memory : 4.98GB
Memory : 19.84GB
Peak Memory : 19.84GB
19.84GB RAM required to build the scene and 4.98GB VRAM to render it on the GPUs?
Displacement XPU/CPU difference?
909 5 0- Crosby
- 2 posts
- Enivob
- 2537 posts
- jsmack
- 7771 posts
- Crosby
- 2 posts
- dlee
- 425 posts
Crosby
I do understand that the engines are different. I noticed that with XPU I hade to connect the MtlxNormal to the normalmap node and disconnect it for CPU to get the correct result.
Does XPU need more RAM to calculate displacement vs CPU? Nnoticed that I run out of RAM quicker with XPU in this scene.
That's bizarre! You shouldn't have to wire in Mtlx Normal (unless you need to feed in different normals or in different space) but more importantly CPU and XPU shouldn't interpret it differently. Can you please file a bug with an example scene? Thanks!
As for memory requirement... displacement on XPU *can* require more system RAM depending on how many per-point/vertex attributes the base mesh has, but if that's not the case the discrepancy is likely coming from elsewhere (or perhaps innocuous virtual memory usage).
- jsmack
- 7771 posts
Crosby
Displacement is mutually exclusive with normal maps. There's no way to use it without importing the pre-displacement normal. The normal map is meaningless to the displaced normal, using both will result in a strange look.
