When building an HDA, I will often promote parameters from nodes inside by dragging the child node's parameters into the "Edit Operator Type Properties" dialog, but I'm running into a case where I can't do that. In LOPs, I'll often come across an icon button that has options such as "Do Nothing", "Set or Creation", "Set if Exists", etc., but if I try to drag and drop it the same way, it'll just open up the menu instead. It feels a bit silly that I can't figure this out, but how can I easily promote these parameters to the HDA? Have a look at the attached screenshot to see what I mean.
Dragging and dropping parameters when building an HDA
688 4 1- carlson
- 5 posts
- tamte
- 8622 posts
- kodra
- 213 posts
- Jonathan de Blok
- 256 posts
- carlson
- 5 posts
