Hi!
I can already check each letters of a string to verify if I find numbers but in complicated script. Is there a function that does exactly that?
-Olivier
vex: check for numbers in string?
1321 1 0-
- olivierth
- 1269 posts
- tamte
- 9746 posts
for integer numbers you can use
https://www.sidefx.com/docs/houdini/vex/functions/opdigits.html [www.sidefx.com]
for multiple separate numbers or more complex patterns like float numbers you can use regex functions with patterns fitting your needs
