Is there a list of all the variables $ (local variables?) somewere?.
i'm having a hard time knowing what var dose what in example filles for instance.
Thank you, Tamis van der Laan.
list of houdini variables $
9005 6 1- Tamis
- 58 posts
- circusmonkey
- 2624 posts
- anon_user_40689665
- 648 posts
this has been an ongoing source of WTF posts for years.
what I'd like to see is a popup menu that lists available
attributes for that field, displayed exactly as you would
need to type them.
so when you type “$” it lists all available attributes, “$M” brings
up all available attributes beginning with “$M” and so on…
either that or fix it so that if you can see an attribute in a node's
middle-click info you can just type it in, no more bloody attrib-creates
to get at attributes that already ‘exist’.
also it would be great if the attribute name and the local variable were
one and the same, EG: uv = $uv, hitpos = $hitpos, p = $p, etc…
need to type them.
- Tamis
- 58 posts
- wolfwood
- 4262 posts
cpb
need to type them.
Bah, popups listing all the local variables within a node is so Houdini 2.5.
:wink:
- hoknamahn
- 398 posts
- 648 posts
