Something went wrong connecting to hserver: Could not connec
   3467   11   3
This issue is driveing my creazy I check the server is working but I can't updete houdini to the new virson I keep gitttng this message Something went wrong connecting to hserver: Could not connec
I had a similar problem some months ago. In my case it turned out that my browser's adblocker extension broke the communication.
Turning it off for that URL got rid of the problems.
Edited by Steffen Dünner - 2026年5月28日 17:38:24
I had this same problem a couple of hours ago. My default browser was Vivaldi (Chromium based).
After the error shows up in my default browser, I just copy/pasted the url https://www.sidefx.com/login/launcher/ [www.sidefx.com] into Firefox instead and I was able to update the launcher and install a newer Houdini version.
Same problem
I can't even log in through the license administration window.
Using different browser does not help me.
I'm experiencing the same issue now; even though I get a confirmation window in Chrome, Launcher still think that I am not logged in.
I tried turning off the ad blocker for SideFx, it didn't have any effect as far as I can tell.
http://WinterLightStudios.ca [winterlightstudios.ca]
I had this problem on 3 different systems now. 1 Linux and 2 Windows.
What helped instantly in all cases was clicking the "Logout" link in the displayed browser window and then directly logging in there again.
Like I described here: https://www.sidefx.com/forum/topic/83318/#post-460494 [www.sidefx.com]
Edited by Steffen Dünner - 2026年6月6日 12:12:29
Same issue here! The launcher is stuck in a loop of Logging In -> Login Luckily, I'm still able to use the program else I'd be pulling my hair out.
"Steffen Dünner"
it worked for me
Unfortunatly logging in with any browser will no longer work, until Houdini 22.0.
The Tech Support team has created this online FAQ to help with this issue:
https://www.sidefx.com/faq/question/server-replied-failed-to-log-in-error/ [www.sidefx.com]
Side Effects Technical Support
