after many days and nights, after many emails, discutions, crying to the moon, etc…
thanks to everyone that helped create the tool, between coments, ideas, hints on how to do things, coworkers, the guys in the forums, Sesi, etc…
here is the first Beta!!!!
http://polybevel.wix.com/fabio-hair-system [polybevel.wix.com]
Fabio Hair System
30852 40 8-
- pelos
- 624 posts
- Camangren
- 3 posts
- pelos
- 624 posts
- Tesla_s_fan
- 129 posts
- GlenD
- 118 posts
Thanks for sharing your work, looking good! Reminds me of Kristinka Hair for Softimage. Kristinka Hair Link [matkovic.com]
Good job!
Glen
Good job!
Glen
- pelos
- 624 posts
Kristinka is more of a overall groom/modeling, base on pre generated geometry. where it use UV of nurbs to drive it.
where fabio is a procedural system, that creates more hair at render time and can provide aditional style to the hair.
something that can work very nicely is having the style done with Kristinka generate a few strands and then plug that into Fabio.
working with inside houdini there are several ways to achive a hair style, (one crazy way is emiting particles from the skull, use forces to provide the style, make them twist as the fall down to make some curls, and then make curves from there, and use the skull and those curves in fabio).
Other artist that i work with while I was adding features, they where doing the grooming in zbrush and another friend did some test exporting the curves from modo.
- pelos
- 624 posts
- goldfarb
- 3465 posts
- Alejandro Echeverry
- 691 posts
Very Nice Thanks for sharing!!
- pelos
- 624 posts
thanks Michael the hair curve is back now (funny how Houdini some times deletes parts of the shelfs
Will create a curve and will set one fabio to follow along.
if nothing is selected will create a default line. if a curve nodes are selected at Geo/Scene level will do the setup for each one of them.
and will set the option to use chops lag. (usefull if the curve is animated
…)Will create a curve and will set one fabio to follow along.
- goldfarb
- 3465 posts
- pelos
- 624 posts
- goldfarb
- 3465 posts
- pelos
- 624 posts
- goldfarb
- 3465 posts
- pelos
- 624 posts
- goldfarb
- 3465 posts
- pelos
- 624 posts
- fixed transmition since was not properly multiplying with the spec therefor giving black as result.
- re organize the use clump togle and added another togle “use guides” in case the user just provides normals(works on the fur sop, doesnt work with procedural pending to check)
1.7.8
- accommodate the “use guides” toggles from 1.7.7
- now can use the normal of the skin if the use guides is turn off. (thanks sesi for helping out with this)
1.7.8
- Mr Commentno
Thanks for making this great tool, I've been using over the last couple of days and love it. A couple of things…
It doesn't seem to work with Houdini 14 properly:
-When you add guides all the hair disappears.
-When you try and use Pop hair on the shelf it gives the error ‘NoneType’ object has no attribute ‘set’
So in the mean time I've been using it with 13.
Could you help with this- I want to shade with a colour along the curves but not by using the parametric length but rather absolute length. That way say a hair can get blonder the longer it is and the short hairs will stay dark.
I created a point attribute on the guides where short guides will go from say 0 - 0.3, and only the very longest curves will go 0 - 1. Using this attribute in the shader works well but only on the hairs that are affected by a clump, normal hairs don't seem to get the attibute. Do you know why/is there something you can change to make this work?
- pelos
- 624 posts
